Broner said:Jeez Dave. So you hooked me up with a pair of overly bright speakers that only work well up close. I might need to search for something different then...![]()
He used to sell hi-fi, you know. 😉
matt49 said:Broner said:Jeez Dave. So you hooked me up with a pair of overly bright speakers that only work well up close. I might need to search for something different then...![]()
davedotco said:The OP may like techno, but he might like it played through a smooth warn conventional hi-fi setup. We really do not know. Until we do, we are talking in general terms.
Overdose said:As another option, if wanting to top out your budget, the Quested S8Rs could be had for under £2k (the S7Rs even less), leaving some spare for a DAC/Pre.
I think I'd still want to get a listen to the ADMs though, as you would'nt need anything else, plus have plenty of cash left over for music or whatever your poison is.
JMac said:lol, looks like I'm going to have to put a few weekends asside and source some places that have stock. I live close to Leeds so I should be able to find somewhere nearby. If it helps, and for those aware of the artists, DJ's typical of my preference would be Sasha, John Digweed, Dave Seaman and the ilk. But add to that some house music from the likes of Graeme Parke but then also techno from Dave Clarke.
As for delivery style I think I'd tend to lean to sharp, accurate and fast delivery with tight control but not overly bright. I love a wide soundstage and being able to place exactly where the track artist is intending the sound to come from in front of you.
I have to be honest and say that I do struggle with the industrial design of the monitor/pro grade equipment and whilst I accept it should be function over form, looking at speakers suc has KEF R300's or B&W CDM1, they're simply gorgeous just as objects.
JMac said:How do you gauge volume without moving into dB(A)? They'll never be used for a party but I have been known to crank it a little higher than normal when nobody is home.
davedotco said:This will still go pretty loud by hi-fi standards, no problems if you want to wind it up a bit.
JMac said:The traditional hifi aesthetic isnt essential but I wold prefer speakers that are nice to look at in a room if possible but as I say, not essential, The RS's do have that in their advantage but I'm sure I could get used to the look of the Events or similar black cased monitors.
