Good HDD for a NAS
Twill
124
Anyone got any good ideas for a good value HDD to go in a NAS enclosure?
I'm getting a Synology DS112J, and notice that the version that comes loaded with a 2TB HDD already is more expensive than buying the enclosure and a separate HDD.
I don't really know anything about HDDs, so where's the value in this market when it comes to NAS applications? 3.5 or 2.5, what spin rate, green, specific brands, anyone got any experience?
Thoughts welcome, thanks.
John Duncan
Whether it's 2.5 or 3.5 will generally be NAS-dependent. Just checked the Synology and it will support both, so choose whatever gives you the best balance between price and storage. 3.5" will be available in much bigger sizes and - generalising - will be a bit cheaper for the equivalent drive for the same storage. What's not to like.
If it's just acting as a music server then 5400rpm will be fine, but if you want to use it for more general storage you might appreciate a 7200 disk. TBH there's not *that* much difference between them in price so I'd get the faster one unless you're absolutely trying to minimise outlay...
Twill
124
Thanks JD, much appreciated.
What about these environmentally friendly green drives? Any idea if they're worth considering? As per my Sonos thread elsewhere, this can be an issue for me.
Thanks again.
Xanderzdad
146
If sound is a consideration a 'green' hdd (spinning at 5400) will run a fair bit quieter and cooler than a 7200rpm one. For most purposes i.e. streaming you wouldn't normally notice a speed difference in real world usage between the two. The exception possibly being intensive HD video combined with other access to the same disk such as other people streaming from it simultaneously.
jockey.wilson
9
I run a Synology DS212j with two Western Digital Caviar Green 1TB drives. No reliability issues and both run quietly and relatively cool, with the warmest only ever reaching 38 degrees in my installation (inside a box)...
