SlickenSmooth: Frank,David
First off thanks for all the insightful information that you've been putting in this topic
.Pleasure.
I'd like to know if a Marantz PM7000 KI could drive 'em or is it too weak?It'd drive them to an extent, but not to their best. I used to like the PM7200 a lot - I always thought it was one of the best amps under £500 along with the Rotel RA04 - if these 2 amps couldn't make a speaker sound good, nothing else could.
Your comment about how important the amp is made me reconsider, maybe I should get some Monitor Audio RX-8, which I auditioned today on a Marantz PM8003 and it sounded nice but was lacking bass and body, then the shopowner hooked it up with a Advance Acoustic MAP 305 DA II (although only 2 stars for What Hifi) and they sounded amazing. Also they gave me the impression that they're friendly with a lot of types of music. That gives me around 1000-1200 quid for a good amp. What do you recommend for these RX-8's?Not sure how the RX8's lacked bass, that's usually the one thing Monitor Audio speakers don't lack! Were they positioned correctly?
The RX8 is a livelier speaker than the A5, but real instruments will sound more like real instruments on the A5's. If you want to spend £1k on the speakers, I'd buy the ATC SCM11's which is easily the best speaker under £1k (ProAc Tablettes a clos second or equal depending on individual taste), and that'll leave you a little towards some good peaker stands speaker stands.
dim_span:I still maintain that if I had spendor A5's ... and £1500 to spend on an amp, I would not hesitate to buy the krell KAV-400Xi ...I'd recommend people try out Krell rather than buying it blind. I made that mistake, but luckily gt back what I paid. I thought the Krell would easily drive and control the KEF References I had at the time, but i just didn't work. The bass was loose, there was no 'snap', and it just didn't sound anything like what I'd come to expect from Krell after everything I'd read. I'd much prefer Bryston as I've achieved much better results from what I've tried and owned in the past.
