Hi
I have an old 42" Sony rear projection TV that is now taking 10mins to warm up and display a picture
. I also have a Denon AVF100 surround sound system that I paid a small fortune for a few years ago, but is hardly used as babies/kids came along shortly afterwards and the subwoofer was just too loud - plus I haven't had the time to use it
Thus I have been considering 2 options:
a) Buying a top of the range TV and either trying to integrate/upgrade my Denon to blue ray cheaply, or ignore the surround sound for the time being and upgrade it with like for like Denon when they release it and when I can afford it (likely next year at best)
b) Buy a cheaper Sony lcd TV and go for a Sony all in one blue ray surround sound package (although after initial browsing I'm a bit confused as to what I should be going for).
My initial feeling is that the like for like Denon upgrade is going to be too expensive and would possibly end up requiring a full replacement which would be gutting. Also an all in one system would allow me to use the Denon either in the conservatory on a 32" HD JVC lcd or in our bedroom as a hi-fi.
If I was to go for a top of the range TV and forget HD surround sound then I was looking at the Pioneer PDP-LX5090. If I was to go for an all in one Sony TV and blue ray surround package then I was looking at the Sony KDL-46W4500.
Any advice on the 2 TV's and possibly more importantly what I should do with my surround sound would be most appreciated. Also is HD sound as much an improvement as HD vision and would I be blown away by it?
Thanks in advance.
Richard
Thanks in advance.
Richard
