I have one album, Prong-Ruining Lives, which plays at 45rpm, rather than 33. Is there any particular reason why this would have been done? And sound/quality reasons?
Al ears said:Hi Bigfish, you might find the link below of interest. I have several albums recorded at 45 RPM although these are usually Classical or Jazz / Blues.
http://forums.stevehoffman.tv/threads/why-45-rpm-great-45-rpm-12-lp-explanation-by-kevin-gray.132280/
David@FrankHarvey said:There is an increasing number of albums being released at 45rpm nowadays. Queens of the Stone Age's Like Clockwork and Foo Fighters' Wasting Light spring to mind, many Mobile Fidelity releases like those from Bob Dylan, most Analogue Productions release are 45rpm and on 200gm vinyl too, like The Doors L.A. woman and Credence Clearwater Revival releases.
Despite the claims of digital superiority, I find it odd that even standard vinyl usually outperforms digital releases for dynamic range.
Al ears said:David@FrankHarvey said:There is an increasing number of albums being released at 45rpm nowadays. Queens of the Stone Age's Like Clockwork and Foo Fighters' Wasting Light spring to mind, many Mobile Fidelity releases like those from Bob Dylan, most Analogue Productions release are 45rpm and on 200gm vinyl too, like The Doors L.A. woman and Credence Clearwater Revival releases.
I quite agree. I have yet to hear any mp3 file that sounds better or even as good as my vinyl set-up. I have a feeling many others feel this way too and this has only assisted the current trend in turntable sales and associated vinyl 'revival' (although in my case it never went away.)
thescarletpronster said:Occasionally albums were released on 45 even 'back in the day', for example Rip Rig + Panic's first two albums (both brilliant, by the way) from 1981 and 1982.
*ROFL*Anderson said:You can rip vinyl to MP3 and it sounds exactely the same as the original.
David@FrankHarvey said:*ROFL*Anderson said:You can rip vinyl to MP3 and it sounds exactely the same as the original.
Al ears said:Now now David. Perhaps it does on his system.
Anderson said:Its the mastering not the format, digital is the middle child, so much potential but wasted because he wants to get high every day instead of studying for good grades. Vinyl is the first born dumb kid, makes up for his ability by putting time into studying and etyig the grades. Modern life.
David@FrankHarvey said:Al ears said:Now now David. Perhaps it does on his system.
I know he mentions in his sig about disconnecting his brain, but I can only presume he's already disconnected his ears...
Of course, any format recorded to a digital format will sound (basically) the same, but only within the limitations of that recording format. Compressing a vinyl signal to MP3 may well retain certain vinyl characteristics/distortions (call them what you will depending which side of the fence you sit on), but that doesn't mean that the MP3 version you're listening to "sounds exactly the same as the original". Compression aside, you've still got the D-A and A-D processes that will have their effects. I know what is coming after that statement, but if you compare products that use different DAC chips (Wolfson/Burr Brown etc), there are differences to be heard.
David@FrankHarvey said:Anderson said:Its the mastering not the format, digital is the middle child, so much potential but wasted because he wants to get high every day instead of studying for good grades. Vinyl is the first born dumb kid, makes up for his ability by putting time into studying and etyig the grades. Modern life.
*fool*
Al ears said:I concur. To my mind you cannot get any higher 'resolution' than a pure analogue signal anyway.
MajorFubar said:Al ears said:I concur. To my mind you cannot get any higher 'resolution' than a pure analogue signal anyway.
Theorectically that should be true but the trouble is they haven't invented an analogue recording and distribution system which doesn't add a load of noise and distortion by its very nature. And of the various analogue media that were once popular, records were the worst culprit.
David@FrankHarvey said:I've heard a few people say good things about that release, and L.A. Woman by The Doors.
macdiddy said:" time out " by dave brubeck on double 45rpm vinyl, currently going for £105 on amazon.
*music2*
