Whats your take on the limited edition Beresford
Caiman, Chebby?
Excerpts:
What you get for your money
WM8716 - 64x, 192KHz oversampling DAC chip.
The majority of high-end consumer DAC chips are only 8x oversampling
types. The Caiman DAC chip is only matched or surpassed by the DSP
based DAC chips. As far as we know, the Caiman is the first and only
DAC that makes sole use of the latest 64x oversampling technology in an
affordable consumer aimed product. [*]
Filterless analogue circuit. There
has been much debate as to how much damage is done to the audio signal
by the various filtering networks that are found in a DAC. The new 64x
oversampling technology used in the Beresford Caiman does not require
the use of any anti alliasing filters. This makes the Caiman the first
off thye shelf DAC on the market that does not use analogue filters in
the audio signal path. [*]
LM4562NA - Recording Studio specification audio operational amplifiers.
The 64x oversampling technology requires a far higher slew rate from
the audio chips in the signal path if the extra speed, detail, and
accuracy of the decoded signal is to be maintained at the RCA/PHONO and
headphone socket output of the Caiman. [*]
Class-A headphone amplifier circuit.
The new generations of high-end headphones have up to now only been
able to operate properly on expensive stand-alone headphone amplifiers.
The Caiman inbuilt headphone amplifier is designed to drive even the
latest range of high-end headphones and reproduce musical detail that
these new headphones are capable of.[*]
Microsoft Windows 7 ready USB input.
Wonder if this will be any match to the guys at
Audiophile Upgrades.
