Still kicking the cartridge thing about . . . thinking during the day, I used to adjust the VTR to good advantage in the old days with an Allen key and slide the arm up or down a tad, very technical mesurement is a 'tad' . . . the Rega uses spacers, limited finesse. So be it, until one reads in the destructions . . . "use the spacers if the cartridge chosen is deeper then a Rega cartridge" . . . that's fine, but they dont say how deep a Rega cartridge is!!!! a little arrogant I feel?
OK, I seem to remember reading 'Rega cartridges are 15mm deep'? Cant find anything on the net, anyone confirm '15mm deep'. Measured the Ortofon Blue its 19mm, need the 4mm shim and a 'sleeved arm nut' again no explanation!
In fact reading other cartridge blurb, 19mm is the more common dimension . . . ?
Even more confused, I've seen 3 point fixing shims, but it looks like the Rega shim is a straightforward round shim, arm fitted RB700. . . ??? Dealer protection, driving me mad, treating the user like a numpty, its not a dificult job for those of use who like to be 'in control', but one needs the right infomation! . . . bet there is a special spanner required?
not happy . . . CJSF
