Floorstanders base support help needed....
Jonesiani
17
Hello all.
The mrs doesn't like the fact that my speaker spikes go into the nice carpet. :cry: , however she is fine if I choose to stands the speakers on a base.
So......I have bought some spike shoes, and I was thinking about a pair of granite or wooden slabs. The shoes will go onto the slab, and the speakers on top of them.
Now, what would I put underneath the slabs (if anything) that would isolate to an extent, but not pierce the carpet?
Crocodile
38
You need to show her that the speaker spikes leave no trace whereas a granite slab will completely crush the pile over it's entire footprint. If she still thinks that's a better solution then there's not much hope really...
shooter
210
Your better off to spike the speakers, if you put a base down on the carpet it will leaver an indentation similar to what a sofa or table will do, then she will be....
