- Sep 19, 2015
- 27
- 0
- 0
With Dbpoweramp i can rip my cd's in best quality Flac or Wave and stream this from my Qnap to a Pioneer N50A. But which is te best? A dealer said to me Wave is the best. What do you think?
Hi,loneranger said:With Dbpoweramp i can rip my cd's in best quality Flac or Wave and stream this from my Qnap to a Pioneer N50A. But which is te best? A dealer said to me Wave is the best. What do you think?
jjbomber said:FLAC files are a lot smaller than Wave, so take up less space on the hard drive. That is why most people use FLAC
manicm said:And I'm up for a bit of troublemaking.
http://www.enjoythemusic.com/magazine/viewpoint/0716/Why_Do_WAV_And_FLAC...
Part three reported that a FLAC file sounded inferior to the WAV file from which it was made, and we found to our surprise that when these FLAC files were reconverted, the resulting WAV file did not recover the full sound quality of the original.
manicm said:Major, it's very clear to me that you did not read the piece completely/properly. The gist of the piece is that repeated metadata application in the multiple conversions i.e. album art etc, could affect playback - and they did blind testing to back things up. Their recommendation was to apply metadata at the final file only. They tested with dbpoweramp.
Hi Mr andyjm,andyjm said:manicm said:Major, it's very clear to me that you did not read the piece completely/properly. The gist of the piece is that repeated metadata application in the multiple conversions i.e. album art etc, could affect playback - and they did blind testing to back things up. Their recommendation was to apply metadata at the final file only. They tested with dbpoweramp.
manic, if you were to test a file compression programme, the first thing you might think to test is whether the wav to flac to wav conversion introduced any bit errors. This seems to have passed the writer of the article by. Instead he seems to be measuring the quality of the compression algorithm in inches which I have to admit is a new approach to me.
i am afraid I am with shadders in reaching the conclusion that the writer doesn't have a clue.
thats a fair point I hadn't considered, but of course that means dbpoweramp is bugged and not fit for purpose, not that the FLAC files are actually different. To remove even that as a variable, the only indisputable way to prove or disprove the files are the same is via a null test. Anyone with a computer and an ability to download eg Audacity, can do it. No golden ears or blind testing required.abacus said:One thing I have noticed in all the tests mentioned, (I presume the blind tests were documented) is they all use dbpoweramp for encoding/decoding, therefore if you hear a difference, then its most likely that the dbpoweramp encoder/decoder is not up to the job. (I.E. Its introducing errors
shadders said:Hi Mr andyjm,andyjm said:manicm said:Major, it's very clear to me that you did not read the piece completely/properly. The gist of the piece is that repeated metadata application in the multiple conversions i.e. album art etc, could affect playback - and they did blind testing to back things up. Their recommendation was to apply metadata at the final file only. They tested with dbpoweramp.
I do believe you have confused me with somebody else.
Regards,
Shadders.
