on a pair of GR20's...
It's not that bad.....
the muppet I bought them off ebay didn't pack them properly so one of the top corners has been bashed enough to crumple the veneer loads. Not enough to pierce the cabinet... but it doesn't look far from it. (how thick are the walls? anyone know?) damage goes down about 4mm in from the (rear) corner.
Any idea if there is anywhere I can get this fixed? there is another scuff on the front corner of the same speaker, but it's the kind of thing you might expect on second hand speakers I guess.
