If you ever spot Spam (either in the forums, or received via forum direct message) please use the Report button at the bottom of each post to make sure a Moderator can handle it quickly. Thanks for your help in keeping things running smoothly!
Never done it on the new 3 point mount but have on the older RB250.
You will need to be able to realign the tonearm afterwards as I believe you need to remove it to fit shims
anyway fitted my at vm540ml cartridge without a shim and so far all seems good but i might still put some 1mm washers under the tonearm fixing screws to move it up slightly. I can`t go up much more than that as the tonearm weight will hit the lid.
