Fatman Purchase
I recently purchased a Fatman ivalve doc. The on-line retailer advertised the newer 2x25W model, but when it came the box (and instructions) say that it's the 2x13W model.
The retailer claims that I have in fact ben supplied with the newer 2x25W model, and that packaging is, in fact incorrect.
IS this the case ? And if so how can I tell that the model I have supplied is, in fact the 2x25W model as there is nothing on the item to distingish between the two models ?
matengawhat
695
15
18,895
sound like a load of rubbish to me - surely supplying incorrect instructions/packaging is illegal - H&S etc - also sure a manufacturer wouldn't do it as they would get loads of returns - i'd be sending it back
email fatman your seriel number and ask them to confirm which model it is
Cheers. Yes I agree, the manufacturer would be leaving themselves open to a lot of flack, so I would be suprised if this was the case.
I bought the unit from Audio Affair. This is first foray back into hi(or low) fi for a number of years, so didn't check them out. Some negative comments about them in some threads on the forum. I did point out to AA that they were probably contravening the Trade Desriptions Act (and possibly Fatman also if they have in fact supplied the 25W unit but the packaging/instructions say 13W).
I have emailed fatman detaining the issue, but forgot the item would have a serial number, so have emailed them again with the serial number.
Thanks for the info
So basically you're saying Fatman are themselves contravening the trade desritpions act ! (albeit supplying a 'superior' product to what their packaging says !).
I hope this is the case - but it leaves them open to possible prosecutuon from Trading Standards does it not ?
