robdmarsh said:davedotco said:I
For example, connect your CD player to the WXC-50 using both the digital and the regular analogue cables. Use the fixed (streamer mode) outputs for this test, you can now play a CD and switch between the two inputs on the WXC-50.
I don't think I can do this. First of all, can I even separate the CD signal from the amplifier on an all-in-one like this? Also, although there is aux out on the Marantz, there is definitely no optical out.
It is quite simple.
Connect the Toslink out on the CD player to the Toslink in on the WXC50
Connect the analogue phono out on the player to the analogue input on the WXC50
Connect the aux out on the EXC50 to the 603 aux input 2 or 3
Set the level on the 603 to normal listening levels and switch between the two inputs on the WXC 50, if trying to instant A/B, be very carefull matching the levels.
Done correctly, this will compare the digital stages of the 20 year old Rotel with the digital stages of the more up to date WXC 50, see what you think.
Then, connect the Toslink out on the WXC50 to the Toslink in on the 603, select whichever input you preferred in the previous test on the WXC50 and this time do the switching on the 603, again, take care over matching levels, but see which you prefer.
