Ellam25 - new speakers
CnoEvil
556
14
:clap:
Allowing more time for break-in could sort it for you.
If not, I would (controversially) look at experimenting with cabling.
roten
9
CnoEvil said:
:clap:
Will play around with cables going forward - have Chord Rumour inside the speakers and will try this all the way to the amps
But have to say that the slight difference to my old Eekels is not really a problem. The Eekels are superb for female vocals and pianos.
CnoEvil
556
14
I believe Chord Rumour is silver plated, so I would experiment with pure copper cables like those from Atlas (or Chord do some as well).
roten
9
Finally complete - with brand logos :)
Chris-torb
Hey roten.
Great job.
I am still enjoying my Ellam 25's.
It is a litte over 4 years since, Troels and i made the design, and it is still a very nice speaker.
i would recomend changing the series coil in the lower bass sektion, with a low Ohm 1,5 mH coil. ~0,1 Ohm
This will lower the range 700-1000 Hz by 1 - 1,5 dB, and at the same time, give you a little moore kick in the lower bas.
Not a bad choice. Not bad at all.
And maybe changing the series resistor in the tweeter filter, with a 2,2 Ohm. It gives a littel more headroom, without being to foreward - in my listening room anyway.
chris-torb
roten
9
Chris-torb said:
Hey roten.
Great job.
chris-torb
I have to say these speakers are still mind blowingly great!
I played around with the crossovers, but moved back to default design with 2.7 ohm for tweeter. Suited my room best
Just want to redo the paint job
How did you get Troels to design the speakers? Or did you build the speakers and asked him for crossover only?
Chris-torb
Hey
It is my design and build.
I started with the Ellam xt, and because i wanted higher sensitivity and more massive bas, a 2,5 way using the same speaker units, was a good choice.
Before and after the build process, i talked to Troels about do's and dont's, and when the speakers was ready, the filter var constructed, at Troels home.
Did you try changing the series coil in the lower bass sektion, with a 1,5 mH coil.?
Chris-torb
roten
9
Chris-torb said:
Hey
Chris-torb
I didn't change anything other than the resistor on tweeter. Tried higher and lower values, and ended up back where I started. My room is wood floor and brick with little to dampen any sound
I am now considering asking Troels to help me with a new set of speakers. But not sure how to approach it. Should it be based on one of his current designs?
And did you ship one or both speakers over to Troels?
Chris-torb
roten said:
Chris-torb said:
Hey
Chris-torb
I would try the series coil change - especially if you have a light dampen room.
This speaker has a great potentiale, and its all about getting the crossover right.
At this time, my speakers is installet with a SB acoustic 29 rdc tweeter and a very different crossover. This is not bad at all.
I put both speakers in the trunk of my car, and drowe cross the country to Troels home, where the crossover was designet.
Troels can't help you with crossover construction, if you can't get them to his home. He's got to have the speakers in his basement, where he vil messure the frequence response, and construct the crossover.
Mvh
chris-torb
roten
9
Thank you for the information. I have a pair of Eekels' Mini where I have drawn up a "Bass Extender/Subwoofer". I have wanted to build these and get Troels to make a crossover for them. This would change them to a three way construction with a separate housing for mid and tweeter.
Did you design and build the new crossover yourself for new tweeter?
And is it a Jantzen coil you are using? What number is it? I have no way of measuring at the moment, so need input on change :)
Chris-torb
roten said:
Thank you for the information. I have a pair of Eekels' Mini where I have drawn up a "Bass Extender/Subwoofer". I have wanted to build these and get Troels to make a crossover for them. This would change them to a three way construction with a separate housing for mid and tweeter. Did you design and build the new crossover yourself for new tweeter? And is it a Jantzen coil you are using? What number is it? I have no way of measuring at the moment, so need input on change :)
The coil is a Jantzen coli number 5430, AWG 14, 1,5 mH, 0,1 Ohm.
No, i didn't make the new crossover with the SB tweeter myself. I unfortunately haven't got any messuring equipment, and not much experience in this, but "he" does.
Vi have more than one, very talentet speakerbuilder in this littel country :)
If you get the coil, let me know what you think about the sound. Just before i switched to the new tweeter/crossover, i used the number 5430 coil, and a 1.8 Ohm resistor in the tweeter sektion. I think this was "right on" in my living room.
mvh
chris-torb
