M manicm Well-known member May 1, 2008 2,441 992 20,570 Jul 4, 2011 #1 Hi, when I post a reply to a thread, and then edit it, it seems to cut off some of the text. I use IE8 and IE9.
A Andrew Everard New member May 30, 2007 1,878 2 0 Jul 4, 2011 #2 Not aware of the problem: maybe it's something to do with the compatibility mode thing stickied just above?
F f1only Well-known member Apr 7, 2010 278 0 18,890 Jul 4, 2011 #3 Hi manicm try doing a page refresh after pressing Edit or F5 it cured the problem for me, im on IE9 & it worked just as well when i was using IE8. Regards
M manicm Well-known member May 1, 2008 2,441 992 20,570 Jul 5, 2011 #4 suspected a refresh was in order.
