Ebay dammit!
pba_target
15
Just picked up a Cyrus Dac XP on ebay for a reasonable price (apologies if I guzumped a forum member!). It's to slot in to my system between my Squeezebox Touch and my mono X's replacing a Cyrus 6XP.
So, the question is, what to do with the 6XP, and what do we think is the best way of connecting the Squeezebox to the Dac XP? Cable suggestions and settings on a postcard please!
Sell the 6XP on eBay, if you're no longer using it.
For your Squeezebox to Dac XP, try every possible way of connecting it, using leads you already have, or £1.29 leads available from eBay. Stick with whatever sounds best to you. If they all sound as good as each other, use the cheapest / most convenient.
