GustavAP said:avole said:I've given the Xeo2s extensive demos on a number of occasions, and they are really good value for the money. They're also one of the few soi-disant "wireless" speakers that actually only have 2 wires, the power cords, rather than the normal minimum which is 2 plus the master/slave cable.
The Bluetooth implementation is spot on. I auditioned them using my iphone as a source - instant connection and excellent quality.
If I would go for the Xeo 2 I would probably end up using them over bluetooth for music at times based on mere lazyness, but as I will have to wire them from TV and phono-stage anyway I will also hook it up to my streamer, so for me it would still be some cable job to be done, although get rid of the quite eastetically pleasing, but HUGH Primare amp.
If you add the Dynaudio 'Connect' to the system you can connect all your sources, streamer, TV, vinyl to the 'Connect' and stream wirelessly to the speakers. The 'Connect' also takes over volume and pre-amp duties.
Mains only required to the speakers...*good*
