DVB-T location
I'm upgrading in the next 3 months and want to include a freeview tuner BUT where do I place it? In the DVD, Plasma or discreet? Help pls.
Clare Newsome
1,657
The quality of the tuner is far more important than where you put it. Having several tuners can also be an advantage re recording - for example, a TV with a good Freeview tuner in plus a DVD recorder/hard-disk recorder with a second strong digital tuner allows you to watch one Freeview channel while recording another at the same time.
Having a good Freeview tuner built into your new flatscreen would be the best starting point (our current, Awards issue gives you plenty of excellent examples) - fewer boxes, connections and remote controls from the off....
Wow, that was fast Clare. Many thanks. Can I ask a supplemental? I was thinking of getting a Panasonic TH-42PX700PED and although it shows a TV out can I connect this to an input on the DVD recorder and, at the same time, record from the recorder's DVB-T if you see what I mean. Wouldn't it be better to go the other way? Use the DVD to record (from it's own DVB-T and use the Panasonic's DVB-T like a conventional TV? regards popeye
