I think they are both the same, the LG was in a brighter room which doesn’t do it any favours because you can see reflections in the screen, otherwise I would think they would look identical. Would do you think mate? Cheers.Which picture do you prefer?
More importantly which sound system do you prefer, Buzz?Which picture do you prefer?
Yes, I think you’re right.Sound system in your room is better.
Prefer the picture of the LG.
Great film and soundtrack too!Yes, I think you’re right.![]()
It’s hard to rank with the other two, but it sounds v good and picture look good too, it just has some sunlight going across the screen.Hi Buzz, what do you make of this one with picture and soundtrack in order of best against the other ones?
View: https://youtu.be/tnV3K3ZeU78
Thanks Buzz.It’s hard to rank with the other two, but it sounds v good and picture look good too, it just has some sunlight going across the screen.
Obviously what I’m seeing on my phone watching and listening to the video won’t be the same as what you can see or hear anyway due to YouTube compression, the camera you use to record it and my phone screen and speaker.
Actually no I don’t what was I saying!Yes, I think you’re right.![]()
