Do i need Banana Plugs ?
Im buying a Mission MCube and wondered if i should use banana plus on either end of the speaker cable to connect into the speaker and amplifier or should i just use bare wire and tighten it.
I was looking to get QED Screwloc Banana Plugs but have been told that using bare wire to attach it to the equipment is as good, can anyone advise me pls.
Thanks for replying back, just wondering so why is banana plugs used then ?
scene
It makes the cables easier to get on and off, especially if moving things around. Also, bare wire will oxidise over time, potentially reducing the quality of sound. To get round this, you need soldered banana plugs, or airtight ones, like QED airlocks. If you clean your wires and terminals with isopropyl alcohol (power off on amp, wait for it to dry thoroughly to avoid any fire risk), and avoid touching the bare wires or terminals with your fingers, then you should have no issues. You can repeat this process every couple of years. Badly fitted banana plugs are actually worse than bare wire.
BTW: I have a mixture of bare wires (at the back of wall-mounted speakers) and banana plugs - the latter for convenience, as I found it really hard to screw in the bare wires with my stiff Silver Anniversary cables + close together terminals on the back of my AVR250.
As previously said either is option is fine.
I use banana plugs cos i find them easier to plug/unplug leads especially at the amp end of things and i find they look neater.
richardw42
299
When you've connected two of your five speakers by bare-wire, you'll know why you should choose plugs at least for the amp end. The more wires go in it gets progressively mre fiddly and time consuming.
And make sure there are no stray strands touching each other.
Don't think I'll ever go back to not using plugs for HC or Hi-fi.
Yes it makes life easier when unplugging cables in the future. Also means you dont have to keep trimming the cables everytime you undo them and they are dusty, frayed or some strands have snapped.
