Do I need a Phono Pre-amp?
Kloëtjüpke
17
I recently acquired a Rega P2 with Nd3 cartridge. Previously I had an old Dual cs-505-2 with Ortofon OM10 cartridge.
After installing the Rega I have to say that the sound is rather disappointing compared to the Dual. Could it be due to the running-in time or is the Rega simply a lower quality record player? The vocals in particular are noticeably soft and there is little depth in the sound overall. I play this record player in combination with a Rotel A14 MKII amplifier and B&W 606 speakers.
The Rotel has a built-in phono pre-amp. I am now wondering whether I should purchase an external phono pre-amp to take the sound to a higher level. What do you think about this, would this help? And then of course the question which one, and without spending too much money? I would like your advice.
Integralista
213
74
370
Hi, your Planar 2 and same new cartridge nd03 are both classleaders. They both but cartridge more need to runn in as you wrote. Than your Rotel A14mk2 is very good amp, with a lot of energy. Rotel is just not specialist for phono stages. Here a saparate phono like Rega Phono MM will soumd a lot better. I remember also your old Dual 505mk2, this was quite good player.
Reactions: Kloëtjüpke
I would disagree, he is comparing the two decks using the phono stage in the Rotel, which is quite good.
This is his reference so he has to work out why the Rega isn't sounding better because it certainly should.
It would be interesting to see if he bought new because if he did there is something wrong with that cartridge.....
I suspect that the turntable hasn't been set up correctly or the cartridge is bad as the Planar 2 is not normally sold with that cartridge fitted.
The ND3 should be way better than the OM10.
An external phono stage isn't going to help.
Perhaps the OP could explain where he "acquired" it from......
Kloëtjüpke
17
FYI: I bought the Rega P2 new, including the factory-installed Nd3 cartridge (available in the Netherlands).
Thanks for the advice, I will contact the dealer.
How close is the volume between the two? If the Rega is much quieter you may be mistaking that for a weaker sound, but I believe the Nd3 claims 5-6mV output nominal, which shouldn’t be quieter.
Don’t be fobbed off with ‘running in’ either. It should sound great as long as you have the correct tracking pressure and a warm room. (A cartridge brought in from a cold car luggage area, for example, won’t sound at its best).
PS. You definitely plugged the new turntable into the phono inputs?
Correct. Running in is usually a fob off when it comes to cartridges, they aren't going to improve with time.
Yes there are elastomers involved but if they don't sound right from the outset........
Kloëtjüpke
17
it's not so much that everything sounds softer, except for the vocals that sound more subdued than the rest of the music. I miss the details in the music. I had hoped to hear much more expression and detail, and that's what I miss now. I was actually quite happy with my old Dual 505-2, but because of all the rave reviews about how great Rega is, I gave in and bought one. I hope I didn't make the wrong choice.
I’m puzzled then, as I’d typically expect a new cartridge to sound as clean as a whistle. It’s years since I heard the 505, though I owned a CS601 for decades, but it had a certain energy which I’d expect from a Rega too.
What tracking weight is it at? If maxed out, try a 0.2 gram or so reduction.
