DMR-BW780 Freeview HD signal quality?
Sky Explorer
Wondering if anyone can help...
I've just bought a DMR-BW780 blu-ray recorder and connected it up to my TX-P46G20. When The 780 is switched the G20 HD signals just say "No Signal" and I cannot get any Freeview HD channels, as soon as I turn the 780 off the channels are viewable again.
I looked at the Channel 31 554Mhz quality and it's zero, but everynow and again it goes up to 8 and then back to zero. The Signal quality on the G20 is consistently 8 (the bar is green).
Can anyone help with this, its a bit annoying as having just bought the recorder to record HD...
