Hey guys, I am planning a basic DIY sub build as branded subs are too expensive to import in my country.
I had a question regarding power and driver choice. If I feed a 100W amp into one 4 ohm subwoofer driver, that results in X volume. If I use two 8 ohm drivers of the same type, wire then in parallel to get 4 ohm load and feed them the same 100W amp, will that produce the same X volume, or more/less volume? In other words, is it better to invest in a bigger amp or more drivers?
These are the drivers I am planning on using, these have both 4 ohm and 8 ohm versions:
Order the SB Acoustics SB26SFCL38-4 Subwoofer
Buy the SB26SFCL38-4 online at SoundImports ✓ Same day shipping ✓ Low shipping rates
www.soundimports.eu
