diy record cleaning ideas
shafesk
136
Dear forumites,
I just got back some vinyl that I had lent to my brother. They have been violated to say the least, been scratched and are dirty. Can't bear to listen to the silent tracks as they are full of pops and clicks. Can anyone suggest ways of improving it? Mind you, I cannot get a hold of record cleaning fluid and carbon fibre brushes in my country so home remedies would be nice.
Appreciate the help as always,
Shafin
B
BIGBERNARDBRESSLAW
This is what you want
http://www.amazon.co.uk/CONRAD-Disco-Antistat-Disco-Antistat-Cleaner/dp/B000BFXIVW/ref=sr_1_3?ie=UTF8&qid=1356707474&sr=8-3
But whether you can get it in yourcountry is another thing.
Also, totally agree with the_Lhc on homemade fluid. I used this together with the Disco Antistat, and the results were fantastic, much better than expected. Even my most abused records are playable now.
CJSF
251
Hi BB, do you use the rack supplied to let the records dry naturaly, I have read that some spin them dry in a 'drill?' . Have also read the cleaning solution supplied is best not used leaving a residue, the home made concotions being much better?
CJSF
Everyone needs complete satisfaction when it comes to the cleaning process of commercial kitchen hoods. It can certainly be a bothering and never ending process. So, you need to work really hard. cleaners bournemouth
