L Lenn New member Jul 6, 2015 1 0 0 Jul 6, 2015 #1 Hello If my turntable has a built in preamp will I experience problems plugging it into a phono stage of an amp? Regards Lenn
R RobinKidderminster New member May 27, 2009 582 0 0 Jul 6, 2015 #2 Yes. Don't Plug it into the line level or disable the tt preamp. Compare the two.
Al ears Well-known member Nov 23, 2008 13,846 8,406 64,070 Jul 6, 2015 #3 Robin is correct. The inbuilt preamp will, in my experience, be inferior to the phono stage in the amp itself. However try both and see which you prefer assuming you can bypass the phono preamp on the turntable.
