Denon D-M37 DAB Speakers
Buying a D-M37DAB all in one system and would like some advice in what speakers are a good match for this, been looking at the wharfdale diamond 10.1 s, any advice greatly received
Put in DM37 speakers in the 'search forums ' box will show that the DM37 is being used with pretty well all the range of budget speakers from the WHF price guide. Seems to work well with almost anything.
Tannoy F1 Custom, Q Acoustics 1010i or Diamond 9.1 (v v cheap at the mo, and not sure the 10.1 would be worth the extra with the Denon tbh, though admittedly haven't heard them).
take a look in the hot deals section- I posted a link to the speakerless unit for £179.
The £99 Diamond 9.1, as suggested by JD, would be a great budget option.
i have thesame amp. i have paired it with Bower wikin 685. people have said it does not work in theory. i agree. but the only way wto try is to hear it. they sounded far better than other cheaper or more expensive, they also allow for more powerful amps if you upgrade later on
Today I compared Onkyo CS-525 and Denon RCD-M37DAB. It seemed to me that Denon was a little bit better, so I decided to buy it. Unfortunately I couldn't try Denon "matched" speakers SC-M37, so I don't know if I shoud choose SC-M37 from Denon or Wigo 110 or 130 from Audio Pro. Do Denon and Audio Pro match technically? Which speakers would be better?
http://www.audiopro.com/templates/audio_pro_products/?id_products=482
http://www.audiopro.com/templates/audio_pro_products/?id_products=484
