Denon AVR-1910 and KEF KHT2005.3
Simon Pinkney
30
I have always had an out of the box cinema system but I am now wanting to move to separates as this seems the way to go and after reading loads of reviews on what-hifi and confusing myself further with whats out there I have decided to purchase the following: -
Amp
DENON AVR-1910
Speakers
KEF KHT2005.3
I will be connecting a Samsung Blu-Ray player to it and a sky+ box (Not HD yet!).
However, before I do make the purchase can anyone let me know if this is a good set up and what else I should/need to consider before buying.
Cheers and thanks in advance!
Simon
ear
118
one thought...kef 3005 expensive? yes.C series speakers expensive? no...why not build a set on C series?they have the same expansive tweeter than the 3005.
True Blue
185
Yep the Denon and the KEFS work wonders (see sig) fair enough I have the 3005's but I heard the 2005's and they were cracking. Enjoy. If you get the stands remember only certain speaker cable will fit through them I can personally recommend QED Silver Ann :)
lobby
161
I think that system will work well together, i would also consider the Onkyo 607 amp, what is your budget.If your considering sats then i would also look at MA Vectors, Tannoy Arena-lites, if going down the traditional bookshelf speakers then the Q Acoustic 1010i at £350 is a steal, better for music with 1050i floorstanders as upgrades to the fronts. Don't forget some decent budget speaker cable, making sure you have enough to the correct lenghts and a sub cable.
True Blue:Yep the Denon and the KEFS work wonders (see sig) fair enough I have the 3005's but I heard the 2005's and they were cracking. Enjoy. If you get the stands remember only certain speaker cable will fit through them I can personally recommend QED Silver Ann :)
I use the QED Silver Ann with my 2005.2 set up. I can certainly recommend it. It threads nicely up the stands. Even 'the wife' noticed an improvement over the Cable Talk 3 we had previously.
Simon Pinkney
30
Thanks everyone for the advice... nice to know there's help out there when needed! I'll have a look at whats been suggested a go from there
Simon
