When you say plug you mean mains plug?
In that placement it should be shaking the sofa but it can muffle the mid tones (35 and up) and make them sound weak and that is where a lot of impact is (i know this as i used a nearfiled placement once). you need to move it into more open space away from the sofa which could be acting like a big sponge at the moment, just to be sure! a few inches here and there make a big difference. Doing that might give you alot more volume. Not depth volume. Only you know what space you have so move it as close as you can to the fronts. You have a rectangle-ish room so should be some what good.
As for the plug just buy a bigger/longer exstension lead for now (a realed one) from a hardware store, should be able to get a cheap one for 5-10
see how you get on..
But remeber that subwoofer is never going to shift air the way a ported subwoofer is going to. Try all the steps and if you really still get no joy trade it in a get a ported subwoofer. The SVS pb1000 should be a direct swap with money you get from it and i have heard for the money its a stunner. You really dont have the room for a BK monolith its massive.
But try everything before you spend more money.
But i think you maybe expecting to much from it, as i have said before the store may have had it turned way up for maxium impact to help sell it. Its an old dirty trick. Also not all films shake the house and there are only a handfull of moments when you will feel in your chest bass the reviews that pass on films as saying "this sequence is deep" can be exagerated.
Take the Super 8 train seqence for example its loud for sure with massive crashing moments but the depth is really only at the begining of the seqence when the train is aproching and when exsplosions are going off 2-3 secounds of real deep stuff and i mean deep sub 20hz. The rest sounds like its more in the 25-30hz region for impact which your sub should able to do nicely.
Films are mixed to be balenced! for a good subwoofer thats been set up right you should never really be able to know it's on till you turn it off , it should never draw attention to its self. You should never be able to hear where the bass is coming from. Ill take that any day over chest crushing "Gary boy" bass as i call it.
I think you have a good balance from what i have been reading i just think you need to move it a round abit to find the happy in between part. Solid Bass with balance. I could be wrong and im happy to be proven wrong.
ellisdj has recently moved from a sub around the same size as yours to a massive SVS. from what i have read he a has only gained more DB's and a flatter response but no more real depth maybe a few hz but he was more worried about impact at 25-30hz he was well aware that his subs would never devel to the depths of SVS ported subs but he favours sealed units. Maybe he can give you some insights as well if he is reading.
But never the less set it manually first and the EQ if you wish. EQing could be doing more harm than good at the moment. Get to know the setup first and make sure you are getting a proper tone from it in the levels. a bitt ramably sorry.
