SteveR750 said:
psurquhart said:
I am presently demoing a Rega DAC doing exactly the above with a Sony DA5400es. Which is obviously alot better than the DACMagic.
It has made a difference - slightly warmer sound and it does sound good - however, i cant justify paying £500 for the experience.
The Airport Express using Spotify Premium is suprisingly good just running through the Sony AV amp. Spotify's bitrates dont really do the Rega DAC justice as they are not using the highest bitrates to take advantage of the DAC.
If however you decide to go down the flac download or highest bit rate download route then thats when the beauty of a DAC merits its price outlay.
I would generally say that you would be wasting your dosh if you are only going to use it in conjunction with the Airport Express.
Hope this helps.
Only to you maybe, others might disagree.
Using lossless itunes on a mac would benefit from a decent DAC, it's a better source than you might think so long as itunes is configured properly and is using a decent driver or the optical s/pdif connection.
Ok - I am not technically brilliant - so you may well have a point. I am interested now in how to get the best out of my itune settings etc ..... I too have a Sony Vaio (like you), itunes and the Airport Express - plus the Rega Dac of course for now.
How exactly do i configure it all to get the best please SteveR ? Your advice would be greatly appreciated. I am obviously not getting the best from the Rega Dac - all my tunes are ripped lossless.
