- Aug 10, 2019
- 2,556
- 3
- 0
I'm currently using a Project Debut III turntable. On well-mastered discs it sounds fanstastic (take the new Foo Fighters album, for example). The level of detail is really astounding.
However, even some new records struggle with "essing" sounds around the inner grooves of the record (a paricular problem on 7" discs, I'm sure you can imagine).
I understand why this is more likely to happen on the inner grooves of the disc as the circumfrance is shorter and the angle of rotation narrower.
So... is there a way to reduce, or eliminate this? What can an improved turntable or cartridge offer me?
Any insights would be grately appreciated.
Cheers,
Rob.
Cheers,
Rob.
