Hi James and many thanks for the kind words 🙂
My experience matches what you wrote. More specifically, the B&Ws sounded a lot better when driven by the Rega Elicit as compared to the Naim 5si and NaimV1+Nap 250DR. The Arcam A29 also kind of struggles with the B&Ws. This 'struggle' is expressed as bass boom and bass overhang. I observed this both in my own living room (more pronounced) but also during the audition (much larger room with acoustic damping all around). The acoustic damping in the audition room helped contain the bass boom but my own living room does not benefit from any such treatment. I did some furtner research and it does appear that the B&W CM1 S2 has impedance lows that reach below 4ohms. Even more interesting that these impedance lows are around the 50 - 150 Hz area of the frequency spectrum. Maybe this all explains a bit why Arcam and Naim are described as not a good match with B&W speakers. It also might explain what some people describe as a full, soft characted from Arcam Amps. A bit curious though how a low DF translates as a (widely reported) superior PRAT by Naim amps. Maybe there is something else that is not measured (yet) and which influences the perception of the Naim sound.
I hope all the above does not come across as a criticism of any amp... I am merely curious after finding it difficult to match amps and speakers.
James7 said:Interesting post Yiannis, and nothing wrong I think with resurrecting a thread like this that deals with a specific, important element of music-making that is rarely discussed. I have come to think that damping factor is a really important element in amp-speaker synergy - there is no right answer here to what the damping factor should be (contrary to some suggestions that the higher the damping factor the better); rather it is a matter of system matching and some speakers, many modern speakers in fact, including the B + W you were listening to, seem to respond best to amps with a higher DF, while others (Triangle, Magnepan) seem to be better suited to amps with a lower DF. Spec sheets can help point in the right direction in terms of putting together an auditioning short-list, but as always listening is the key, and this is where your own findings are interesting.
