Dali rubicon 6 Or some thing different
jase1975
13
Hi all . So in the next 3 weeks i will be getting the audilab 9000a or the rega elcite mk5 unless so one persuades me other wise .
At first the new amp will be paired with may dali oberon 5 floor speakers.
Then there will be an upgrade to the speakers and as i liked the dali 5 .
Was thinking about the rubicon 6
Or should i be looking at other opption and why
As i cannot demo near me advice would be great
Thanks j
Integralista
166
55
170
Hi Jase,
Dali Rubicore is excellent speaker even discontinued before summer 2024. So I hope you get a nice discount on them. This speaker can really rock, play loud with high spl without problem. It also need some size of room to so that it can show its best. If you have more than 20-25 m², it will be OK. Do not worry, Dali is not just for hardrock or metal fans, it will nicely reproduce also some jazz, classic, vocals etc. And it needs a very good amp of course...to shine.
jase1975
13
Hi Jase,
Well the amps i am thinking about are the audiolab 9000a or the rega elicit mk5 . Do you think both or any of these could drive the speakers good enough
