DALI 6 OHM
bubobubo
34
Today i was looking after the lektor serie, and i see all them are in 6 ohm, i have not problem with that, but wonder if Dali had stop to make speakers with 8 ohms? i feel 6 ohm is like a touch of more quality? i hear that speakers of high end use to be of low ohms *scratch_one-s_head*
what are your comments on this, about dalis 6 ohms?
i guess for those that had low watt tubes it going to be more to put instead if they where 8 ohms?
not a big thing i guess (or maybe it is like more durable with 6 ohms and more clear sound (the water flows more easy) *scratch_one-s_head*
regards
The amount of ohms is no indication of speaker quality
Edit-in fact due less resistance, more current flows as you say causing more heat, which some amps struggle with.
can in this case more current that flows make in som what more music to come through making music more "fresh" or "natural"?
if we take a example in the river as more the river flows more faster but more fresh (more refination?) than a water that just goes slowly hahahah maybe i am just in the blue sky here *biggrin*
