Dac necessary
Oct 26, 2014
Hello everyone
my question is ... a have a sony str-dn1050 and a synology ds213 to listenning my music by the network
so it is necesseary to have a dac with my synology (usb dac like hrt microStreamer)
my amp dlna file support format is
MP3 (MPEG 1 Audio Layer-3):
32 kbps – 320 kbps, VBR
AAC (*):
16 kbps – 320 kbps, CBR, VBR
WMA9 Standard (*):
40 kbps – 320 kbps, CBR, VBR
WAV:
8 kHz – 192 kHz, 16/24 bit PCM
FLAC:
44.1 kHz – 192 kHz, 16/24 bit FLAC
AIFF:
ALAC:
32 kHz - 96 kHz, 16/24 bit ALAC
DSD (for STR-DN1050 only):
2.8 MHz, 1 bit DSD
if my amp play a file in 24-bit/96kHz i thimk that the dac it not necessary
thank you,
Although it is possible to comnect a USB DAC to the Synology it should not be necessary. When your Sony AV amplifer and Synology are on the same network, then you should be able to stream music using DLNA. You can download the Synology DS Audio application to a tablet or mobile phone to control this setup and select/play music. I assume the music files on your server are one of the media types natively supported by the amplifier e.g. FLAC or MP3, otherwise you might have to set up the Synology to do transcoding?
