Dac help
Zax89swe
23
Hi i need help picking the best dac around 300euro, Previously I had a better pc soundcard with cirrius logic dac mapped at 101 dynamic range, 101 noise ratio, the crosstalk is 100. To me it had great dynamics and level of details witch I dont want to degree.
Now i want better sound and found vdac mkii and music hall be intressting, but how will they performe??, both got burr brown 1796. I found the music hall performes really high dynamic in 24bit and the dac to be a bit newer.
Vdac mkii vs Music Hall 15.2 dac
THD 0.004% / 0.002%
Dynamic -102db / -115db (-96db 16bit)
Crosstalk -104db / -105
SNR -117db / -110db
your comparing specs. And that's a 'dangerous' route to take in hifi. Even if they have the same chipset, it's only a small part of the total that makes a DAC. So my only advise would be: listen. Listen to them both.
Seeing you have a Brio-R I might suggest you'll try to reach for the Rega DAC. It's a superb DAC, and combined with the Brio R you won't be disappointed to say the least ;-)
