DAB or FM reception
Please excuse which might appear to be a daft question.
I have installed a dedicated DAB aerial - can I use it to receive FM radio?
No. DAB is vertically polarised and FM is horizontally polarised. You could turn your DAB aerial through 90 degrees and it would probably pick up FM, but then you would get DAB!!
Hi Mr. Orange,
I assume you mean you would not get DAB as well as FM should I rotate the DAB aerial.
Many thanks for your response.
How's your future - bright I hope!
strobo
17
Loads of good info available here - http://www.aerialsandtv.com/fmanddabradio.html . With many thanks to this forum (and Chebby in particular
) for pointing me there in the first place.
Dan Turner
158
Given that you can pick up FM and DAB on telescopic aerials on portable radios, and the free 'wire' aerials supplied with tuners then I'd say there is every chance that you could pick up an FM signal from a horizontal DAB aerial or vice versa, but in either case that signal will be compromised and you might suffer from reduced sound quality or at worst audible inteference or break-up.
Give it a go, if it sounds OK then it is OK!
ASK THE COMMUNITY
