Cyrus CD8SE and Amp: 8vs2 vs Kandy K2
Appreciate any thoughts on this. I'm wondering if there are any sonic benefits to matching my 8SE with the 8vs2 amp (can be had for £599), or go for the award winning and best buy K2?
I'm happy with my current amp as to me it's as smooth as silk and a lot more power in reserve than the Cyrus, and just a tad more than the K2.
Or should I just try a PSX-R on the 8SE.
The upgrade bug has bitten! Again.
Graham.
I believe you just answered your own question
EvilWolf:I believe you just answered your own question
Not having heard the others, I was hoping for some input from someone who has really....
My belief is that you'd need to get a PreVS2 and 8 Power, possibly XPower to make a change from the MA worthwhile. If you fancy an upgrade that keeps you on a similar sonic signature, why not hunt for a A5 power amp and use the 3.5 as a pre. Then later change the 3.5 to a proper pre.
Another thought is that MA could upgrade/tune the 3.5 for you (perhaps).
My sentiments exactly
All this constant talk of 'upgrading' makes me weep
let's just enjoy our music.
EvilWolf:My sentiments exactly
Ok. Point taken. Thanks, guys. I think you're right. Right then - MF A5 power.........
Hen's teeth those things!
Says the guy with the high end system. Isn't that the point of this forum though, to discuss equipment?
Pmaninit:
Define 'high end'.... see other post!
Graham_Thomas:Pmaninit:
Each component over £1000, can't be anything but high end!
Andrew Everard:
Pmaninit:Each component over £1000, can't be anything but high end!
Interesting definition...
Ta
I detect a hint of irony in Andrew's post.........
Andrew - do you agree with the assessment - get an A5 as an upgrade not the 8vs2? Cheers.
Thanks Andrew. Some bargain PSX-Rs out there, and I can try and sell again if no real sonic improvement to my old ears.
matthewpiano
Pmaninit:Graham_Thomas:Pmaninit:
Take a look at AVI's website. It seems £900 per component is entry level. LOL!!
Sevenoaks Sound & Vision, at least the ones i've been to, will let you buy Cyrus gear and return for a full refund within 3 weeks!
Pmaninit:
My kit 'high-end'? It's barely even mid-end, in my opinion. Maybe if I had Plinius/Leema....
Mike_Schmidt:Heres what I would do, put the PSX on the CD player and someday send your amp back to MF for a upgrade or tune up. There really really good amps and better than Cyrus gear IMO.
Hullo Mike. Think I will try the PSX-R. Anyone lend me one for a year or two?
The MF 'fine-tuning' doesn't extend to the A3.5 as yet. At £400 I find this a tad expensive to be honest. The PSX-R from £350 seems to be better value for money.
I would run your system off one of these, your noise floor will disappear on your music.
www.airlinktransformers.com/transformer/bps2000-balanced-power-supply.asp
