Cyrus Amp, what speakers ? HELP
SeanRussell
6
I have just bought a Cyrus 3 amp and now need some speakers. Here is where the problems starts, I only have a limted budget but it seems that there arnt any budget speakers that work with Cyrus due to the enthusiatsic treble.
I will send my music through a DAC and into the amp and I mainly listen to folky and Indie music. Please give me some speakers to have a look out for they can be in any shape or form, brand new or second hand aslong as there budget speakers and dont sound too bright with the cyrus.
Any input or ideas are welcome
Thankyou
it would help if you could set a maximum price. Do you want stand mounted or florstanding speakers? What size is your room?
Cheers :cheers:
Cheers :cheers:
Realistically my maximum budget is around £250 and the room is 13ft x 12ft speakers along the longest side and. I will consider floor standers and standmounters, Thanks for your reply
I've found they worked really well (all be it, it was a Cyrus 8VS2 I had). Heard it with the Aelite 2's, AESprit 2's, AE109's and the Neo 3 V2's and they all worked really well, in particular the AE109's - still a fave of mine as they were my very first speakers alongside an Arcam Alpha 6 amp and 6 CD player)!
The soft dome tweeter just seems to gel well with the Cyrus sound and it calms that slight brightness/harshness that can be there at times but then again this does depend on the quality of sound being fed to the amp etc...
just a thought - another alternative could be these floorstanders.... http://www.ebay.co.uk/itm/Tannoy-revolution-R2-/121061678100?pt=UK_AudioVideoElectronics_HomeAudioHiFi_HiFiSpeakers&hash=item1c2fd69c14 Have never heard Tannoy & Cyrus together but I can see no reason that the sound would be harsh.
Thankyou both very much. They both look like they could be just whats needed to tame the Cyrus, will apple lossless files run through a DAC be okay sound quality wise ?
If possible take along your amp to a dealer & audition the AE`s
Another floorstander alternative - Tannoy V4
kev g said:
If possible take along your amp to a dealer & audition the AE`s Another floorstander alternative - Tannoy V4
You have just saved me a post, as I've heard the Tannoy V4's have quite a sweet treble and they received a glistening review from WHF. Ill put them on my fast becoming long "short list"
Yup 🙂
All my music is via iTunes, AirPlay and an ATV2 for my living room system... No issues with sound quality at all 😀
SeanRussell said:
Am I being naive or would the wharfedale 10.1/10.3 be a okay match aswell ?
They'd be fine but you can do better!
The AE Neo 3 V2's are available on eBay for c£250 IIRC.
The AE speakers are much better overall that the Wharfedale's IMO. The Wharfedale's are good speakers but they are budget speakers; the Cyrus deserves better I feel
I had a hunch that would be the case, I think im going to organise an audition with the Neo 1 V2's and the Neo 3 V2s and the others that have been recommended.
Thankyou once again
