I didn't notice if you said you are using a Windows machine or a Mac. If its Windows, then the above suggestions will work well. If you are using a Mac, I would suggest Max (http://sbooth.org/Max). I would caution though, I just cannot imagine using 128kbps for any situation as its effect on sound quality will be huge. 320kbps is an OK compromise if space is a concern instead of using Apple lossless or FLAC, but 128kbps is highly compressed and will be apparent even on average equipment, never mind quality amp/speakers/headphones. Is space the primary concern here, as once you've converted those songs and gotten rid of the 320kbps tracks you'll always be stuck with the highly compressed music which may or may not concern you - but worth thinking about now before its too late to change your mind.ÿ
