I have just purchased a Samsung QE55S95 and a Q800 Soundbar. (5.2.1 initially)
I appreciate that the Soundbar will connect to the TV using HDMI and take up to HDMI3 (ARC) socket.
My current set-up (also a Samsung TV) is hooked up to a Yamaha AV Receiver, and a 6.1 speaker set-up, which includes a very good quality active sub-bass. (400W SVS 17Hz)
I currently use M&K speakers for F-C-R and for RL-RC-RR
The attached pic shows how the current set-up was hooked up (speaker connect left off) anybody have any suggestion of an optimum way to hook-up.
Plan B would be to finally stop using the Yamaha receiver, & M&K speakers, and plug peripherals direct into TV, but would then need a way to get sub-bass signal to the SVS, it's too good not to use.
