Question Connecting a laptop to a Marantz pm6007
Spuddywuddy
Hi, I'm new here so please forgive any mistakes I make.
I would like to connect a laptop to a Marantz pm6007 which has a built in dac. But it only has 2 optical in's and a coaxial in, not a usb in. My laptop does not have optical out. Thx in advance
Reactions: pete9012s
Gray
You could go from laptop headphone out to a line input on the Marantz.
But something like this might be a better idea:
Note that there's a simple software upgrade said to change its sound very much for the better.
Very few reviews (including the one above) even mention it.
Spuddywuddy
So connect the laptop to the zen dac via usb and the go rca to the Marantz? Would i not be omitting the dac in the Marantz then?
Gray
Gray
That's how you would connect it yes.
But see Muljao's better suggestion above.
Which would make use of the Marantz DAC (and give you the choice of optical or coaxial connection to it).
Reactions: Spuddywuddy
jjbomber
Behringer UCA222 to convert the laptop USB to optical output. Cost about £21. Toslink cable to required length. No brainer. You need to take a digital signal from the laptop and use the superior Marantz DAC.
Haddo85
With apologies for resurrecting an old thread, may I ask a couple of follow-up questions? Same issue as the OP.
The PM6007 manual says, on digital audio input: 'Do not input non-PCM signals, such as Dolby Digital, DTS and AAC. ' - Is this something I'd need to worry about when running audio from a laptop USB to the amp's optical input (via a converter)?
And if going the other route of USB to RCA, which port is best to use on the amp? There is no 'Aux' RCA port like there was on older models, just CD/Network/Tuner. I guess 'Network' , but does it matter?
Many thanks!
Gray
Many thanks!
Answer to question 1: No.
Question 2: No again. All those you've listed are electrically identical, you could use any one 👍
