lindsayt said:Thank you Overdose. Your answer illustrates what I was talking about perfectly.
Lindsayt, why don't you recommend some speakers and give their disadvantages I think would be more helpful to the OP.
BigH said:Lindsayt, why don't you recommend some speakers and give their disadvantages I think would be more helpful to the OP.
hoopsontoast said:If YOU read the OP, you would find with a budget up tp £20k and a room 15x35ft, no bookshelf really is going to cut it. A 6.5" Floorstander is not going to do much better IMO either, no matter how much power you give it.
Its like looking to buy a Ferrari or Aston Martin and someone recommends you buy a Skoda Fabia. It will get you from A-B in perfect comfort, technically flawless for the money and does everything a car needs to do but its not the same is it?
Overdose said:hoopsontoast said:If YOU read the OP, you would find with a budget up tp £20k and a room 15x35ft
The budget wasn't in the first post though was it? That came after the recommendation.
Overdose said:hoopsontoast said:If YOU read the OP, you would find with a budget up tp £20k and a room 15x35ft, no bookshelf really is going to cut it. A 6.5" Floorstander is not going to do much better IMO either, no matter how much power you give it.
And the OP isn't looking to buy a Ferrari or Aston Martin, so to speak, but simply to get from A-B in the manner you describe. The analogy was nearly there, the context, way off.
Edit: you might also like to see post #1 of page two, where I see the OP has just given his budget.
BigH said:I think the ADM9 recommendation was before the room size and budget was known. With his budget and room size I would not consider the ADM9s. I may consider the ADM 40s plus many other more expensive amps/speakers, some panel speakers maybe suitable for that room size, its just a question of finding what he likes and is suitable for his room/budget/music.
Phileas said:Overdose said:hoopsontoast said:If YOU read the OP, you would find with a budget up tp £20k and a room 15x35ft
This is quite typical really. An AVI fan makes a perfectly reasonable suggestion and everyone piles in without reading the thread properly.
hoopsontoast said:Phileas said:Overdose said:hoopsontoast said:If YOU read the OP, you would find with a budget up tp £20k and a room 15x35ft
But its not a reasonable suggestion, as above.
hoopsontoast said:Well maybe it would be best to ask the budget and room size before making a suggestion of the AVI speakers, every time? As other people asked before they gave their recommendation, I fail to see how hard that is.
And the analogy does work, he is looking to reproduce music (transport from A-B) and looking to spend up to £20K (in car terms, very high end). People suggest him a £1.5k product (cheaper but pretty decent car).
hoopsontoast said:Oh and someone disagrees with your favourite speaker brand and then the boys lay in one after each other :rofl:
Overdose said:hoopsontoast said:Oh and someone disagrees with your favourite speaker brand and then the boys lay in one after each other :rofl:
But you and others don't disagree with the brand, largely because those most vocal haven't actually heard them. Your disagreement is with the recommendations of the brand.
I didn't think anyone was laying in, simply correcting misunderstandings.
Phileas said:hoopsontoast said:Phileas said:Overdose said:hoopsontoast said:If YOU read the OP, you would find with a budget up tp £20k and a room 15x35ft
Oh, I thought you'd gone back and re-read the first two posts. Obviously not.
hoopsontoast said:OK it was not the first post, but in the first couple.
Maybe we should define if OP is Original Post or Original Poster, I thought its the latter.
hoopsontoast said:Yes, my disagreement is with the constant recomendations of the brand to every question that is asked.
Would it not be nice to ask first, as I suggested, and other members did do, what the budget and room size is before telling them that the certain two models are all they will need.
hoopsontoast said:If I had that budget I would not know where to start TBH, far too much choice and kit to try!
ReportedIntroducing Kollab, the cutting-edge music collaboration platform! Perfect for artists, musicians, producers, and creatives, Kollab streamlines collaboration like never before. With real-time project sharing and syncing, it ensures seamless teamwork on music projects. Plus, its public projects feature allows for community sharing and enhancement. Try Kollab today for smoother, more efficient music collaboration!
Site link if you're interested: https://kollabsound.com
