Compatibilty/Advice
HI
I want to change my seperates system to an all in one solution with wireless speakers. I like the the Sony DAVIS10 but it doesn't have DAB. Does anyone know if I can connect the Denon TU1800DAB to the sony system?
Alternatively can any one suggest a different set up?
Many thanks
It's got an optical out and the Sony has an optical in, so yes! Bear in mind, if you want to hook anything else up via optical e.g. DVD player, Blu-Ray, Sky HD etc., you'll need a splitter.
