After nearly twenty years of sterling service my Sony HTK215 Surround sound system needs retiring.
I have tried a second hand amp and used parts from a second hand subwoofer to try and scrape a few more years of service but, i think its time to move on.
So as in the attached pic (not mine) the amp is very compact and fits nicely into my AV "cupboard" obviousley the sub is elswehere in the room.
Having looked around at new systems, I cant seem to find one to replace it in terms of its size, I live in a 70's semi detahced property with thin walls so cant really justify a big and expensive AV installation (as much as id love to). So over to you expert types, are there any compact surround sound systems out there of a similar size that would suit my particular situation, as they say "size matters" and a budget of around £250 . It doesnt have to be feature packed or have the latest sound reproduction formats. Thanks for any advice.
