Hi Ambrose, I'll do my best with this one.
I find the Linn cables just sound "right"....ie. No exaggerated treble/sibilance, no lean mids and no ott bass; just a musical sound. The Blacks give a taste of this, with the Silvers sounding similar but better in every department, including detail.
I would only get the genuine article (1.2M), that has not been messed with. It used to be possible to get them on ebay for £115-130, but I don't know the going rate atm. One possibility would be to try and get some "Blacks" for about £15-20 to give you a flavour of the sound, and sell them on if necessary. I find them a fit and forget i/c, which is quite at home in an expensive system....bear in mind that I don't like a cable to introduce any "brittleness" into the system, but produce a clean, clear and musical sound, without reducing the excitement. This is all so subjective, but I hope I've helped a little. Report back with how you get on Cno Edit. Here are some:
http://www.ebay.co.uk/itm/Linn-Silver-Interconnect-cables-1-2m-/130733171987?pt=UK_Computing_Sound_Vision_Audio_Cables_Adapters&hash=item1e704de513#ht_500wt_1282[/quote]
Ok, cable finally arrived Saturday and I have been pc gaming most the weekend. Tired and with a brief slot to test interconnect I did not start with old cable, just plugged in new one, which is a very tight fit I might add.
Also, new neighbours just brought new baby home so listening levels very low.
So my first impression which often stays true after longer weeks of listening are very promising.
I totally agree Cno that there is a rightness about the sound coming through my speakers, it sounds more tangible now too with a cohesiveness not there before. Detailing is good, bear in mind i am just getting used to new super dread stands so lots of change at once to take in. It doesn't sound harsh, far from it, has a element of smoothness but nice and clear.
Best of all I am enjoying music. A really important thing to me is does my foot tap and the timing / dynamics are definately there.
Alot gleend from such a short time!
Thanks Cno as I think I may have found just what I was after, a cable that has boogie, is balanced, detailed and involving.
Ambrose
