johnbutler:
Thanks for all your advice. Am trying out a single wire pair of Atlas Ascent 2.0. (My Audioquest Indigos are bi wired with two runs of cable). Initial impressions are that its not an improvement - while there might be a tiny bit more clarity the bass isn't as good to my ears anyhow. Will let it run in some more and have another listen later. Maybe I should consider going in the direction of VDH Inspiration or Supra Sword as Valhalla are way outside my price range. As I live in Ireland its not always easy to get access to a range of speaker cables to try out. Cable technology has moved on, maybe I'll have to also!
Rick, from what you say it seems that the VDH Inspiration woud sound very good with my system
Hi John
Thanks for your post.
If you've got two runs of Indigo per speaker than as you have more or less discovered they are going to be hard to improve upon from many modern designs (unless you spend a small fortune) for use with your system. So why change? If you still seek an improvement than as i said earllier in the first instance try and find some AQ Midnight cables. I think the Midnight sat one or two models above the Indigo. Hopefully the Midnights should not be too hard to find as they were highly rated and sold well. You should be able to pick up the Midnights for not too much money at all. Even a single run of Midnight in two-two or two-four (bi-wired) form will easliy show two runs of Indigo a thing or two.
Btw, i also use Midnight cables and no they are not for sale.
I wonder why?
The VDH Revelation or the Inspiration Hybrid will provide a big improvement although at a cost. The 800 series floorstanders are bass heavy and need as much control as can be exerted on them. Either of the VDH's will do the trick (the Inspiration even more so - it's very fluid).
A combination (which i used for many years) for you to also consider would be using the Revelation for the bass and the Inspiration for mid/hf. This is a stunning combination and one that can be built up to in time.
I hope this helps.
All the best
Rick @ Musicraft
