For the past year and half or so, I was living with a make shift system and now I might have an opportunity to start fresh again. In this thread, I would like to focus on getting more inputs from the amplification view point.
In the past 6 odd years of HiFi, the amps that I had and truly impressed me are Pathos Inpol2 and Harmony kardon HK990. Unfortunately I do not want to get either of them again (Inpol2, being pure Class A was a heavy heater & power guzzler but made most amazing sound and HK990, though very good, I went through three units and all of them were faulty - no more patience to swap such heavy amps).
From the list of the amps that I auditioned, I like the Devialet and Arcam AVR600 (Ok, I know that AVR600 is no stereo amp but it beats MF M6i so easily, and my initial requirement is for HT 3.1/5.1 set up)
If Arcam was not in the picture, then I was clear that I like amps with Class A bias. However very recently, I got to understand that the Arcam AVR600 has heavy Class A bias for the first 20W or so and it runs on Class A amplification. Then there is Class G amplification.
This made a lot more easier, as initially I want to set up HT. current options that I am considering are
1. Oppo BDP-105 with Arcam P777
2. Arcam AVR600 or AVR750
3. Oppo BDP-105 with any other 5 channel amp
Ideally I prefer one box set up but I love the sound of Oppo BDP-105 and so, if there is a cheaper but good SQ solution with a Power amp then I would consider that.
I understand that Arcam P7 does not have Class G amplification.
Do you think Arcam P777 as well as Arcam AVR750 also has Class G amplification?
Are there any other AVRs / multi channel Power Amp which have some kind of Class A bias or Class G amplification?
If the decision is for Arcam then I will be buying it through dealer only (given the arcam reputation for AVR600). With other options, I am fine going through used market as well!
Speakers that i will be pairing with this set up is either AG Strada or Vivid V1 (front & center) funds permitting. There is no need for a seperate Bluray player as I have Sony BDP-S790. I need HDMI input for sure (be it AVR or Oppo) as one of the other sources will be Mac Mini. Room size is approximatley 6m X 5m and I do not listen very loud.
