Cd player or DAC for yamaha + kef
audipheonix
27
Hello!
I am in budget whether to buy CD player (Choice marantz cd5004 or CA 550c) or use my exiosting CD player (Philips ) with DacMagic. Need Advice? Which will have better Synergy
Frank Harvey
567
The main benefit of an offboard DAC would be if you're going to add other external sources. If not, then replacing the CD player might be a (neater) option. Unfortunately I'm not familiar with the DACmagic - I hear it's good, and so is the 6004 - so it'll be a case of getting a listen to the two if you can. Take your player into a dealer and try out the combinations you wish to compare - preferably on the end of an AS500 and Q100's.
audipheonix
27
Thank for the reply Frank!
Will the dacmagic if feed with lossless filoe will produe same effect as playing cd on the cd players
MajorFubar
690
8
Yes in so far as the potential sound quality of a lossless 44.1kHz 16-bit file is exactly the same as a CD.
hortensio
22
Frank, I have in mind this combo: Nad 355 bee amp+marantz c6004+b&w685....what do you think???
T
the record spot
It's David, he only works for Frank Harvey Hi Fi...! :)
audipheonix
27
So will I go for the DACMAGIC or cd player Marantz cd5004 or CA 550c ? I have a lot of cd's and Flac in pc .How the sound quality compare btw the dac & cd player.
