CD player needed to partner Yamaha Z7
I currently have an Oppo BDP-83 connected to my Z7 for use with Blu-ray,DVD and CD's.
This works great for movies but is a bit lacking in CD play-back.
I realize an AV receiver is not ideal for stereo play-back but its all I have at present.
Could you please recommend an CD player to partner my Z7 for improved music listening pleasure.
Big thanks for your help!!
I suppose that the first question we need to ask you is: what is your budget?
I would think something like a Marantz CD6003 might be a good starting point.
Dan.
Dan, thanks for the reply.
Budget would be up to 1000 GBP. But is it worth spending this sort of amount considering I'm using an AV Receiver ? This is really what I'm unsure about.
Mike
That is a decent budget for a dedicated SACD/CD Player. In short, I would say that having an A/V Receiver does hamper stereo play-back somewhat (compared against dedicated 2-channel stereo components, understandably so).
However, the Z7 is a very capable A/V Receiver and while I wouldn't necessarily suggest to go out and spent mega bucks on a dedicated SACD/CD Player, I would recommend to audition a Marantz SA8003 SACD/CD Player.
Dan.
im not sure if its been published yet , or even if it has taken place , but i recall mr e had a good idea for "the big question" a blind test , where three whfi readers would listen to various av receivers playing stereo music (i think) , and then listen to proper stereo amps , moving up through the range of av receivers until there was no audible benefit , or difference , between an av receiver and stereo amp , this may be of interest to you , im not sure if they used a z7 , but they might have...
Dan, thank you again for your input. The Marantz looks like a fine player and I will defiantly be cheeking it out.
Mike
That Marantz is a bit over the top. I'd go for a lower model unless you need the SACD, which the Oppo does anyway. Budget should be about the £400 mark, else you're paying for subtle difference you won't be able to hear.
The other option is to bung a £200 Dacmagic on the Oppo. That will give you as good a lift in sound as your system allows plus is good enough to handle several upgrades.
Sorreltiger
42
I think the fundamental question has to be which component is limiting your enjoyment. Perhaps you can try (borrow?) or demo a capable CD player with your Z7 and then try a stereo amp with your Oppo?
i think you would be better off with a stereo amplifier , hook up your front speakers to it , and hook up your oppo to it via phono cables , also connect phono cables from the pre outs on the z7 to aux in on the amp , run the speaker setup again on the z7 , with the stereo amp turned up half volume , and set to aux , you will have surround sound as normal when watching blurays , dvds , once you select 5.1 or 7.1 output on the z7 , and when u play a cd , set the z7 to output stereo music , your stereo amp then kicks in once set to cd , the z7 plays no part , and you should get great sound from your oppo via the stereo amp , it works great for me , no need to buy a cd player imo , the oppo should be fine .. just my thoughts ...
I was in your identical position. I home demo'd an Arcam (£1.3k rrp) against my LX91 and I couldnt hear any noticable difference. I'd suggest demo a cheaper CD player, at £1k the Z7 would only mask any differences a standalone player gives. Enjoy your Z7 as it is, I think a stereo amp is overkill as the Z7 is brilliant!
