Received a second hand disc tonight was annoyed because it was covered in small scratches so had polish them out, I have a skip doctor little machine with a wheel on that does the smaller scratches but leaves a sheen on the disc I then usea slightly abrasive polish I usually ise Auto Glym Paint Remover a car polish with a very fine cutting agent in (Aluminium Oxide), this can also be used to bring out larger scratches.
I have heard you can use tooth paste not sure if it is particular brands or not, never tried, anyone else have any tricks for removing scratches, are there any kits out there that are particularly good, have seen re-surfacing fluids but never tried not sure if they are any good.
